Would this be a viable way of cooling a CPU
2 minutes ago, BlaBlaBla said:The question is simple: is it possible to cool a CPU with an glass of water under normal(average user) load? I think that if you add good thermal paste underneath it and add a water pump that would take out hot water out of the cup and put fresh one in to it the PC would run just fine. If many people get interested I might make a test with one of my old CPU-s
Yes and no:
Yes the water would be a great way to retain the heat, as it has a high heat capacity.
But, condensation from the cup could easily kill your components, and the CPU will generate heat faster than the water can dissipate it without a radiator, so it would eventually reach the same temperature as the CPU, and stop cooling it.
it makes sense in theory., but it is not a good idea.
