Snowbreak: containment Zone (steam) - stuck at 46fps and terrible frametimes?
kasdashd
The game "snowbreak: containment Zone on Steam is stuck at 46fps on my PC, with terrible frametimes in the graph of msi afterburner.
Has anybody else experienced this, and is it a problem with my PC, or just poor optimization from the developers?
2 minutes ago, kasdashd said:
…is it a problem with my PC…
How do you expect people to answer that part if you don't tell us anything about your PC?
Fair enough. Got a 5700x, rtx 3060, 64gb ddr4 3000mhz, 2tb gen 3 premium ssd, a gigabit fiber optic ethernet connection, and 1440p 240hz OLED monitor. Neither GPU, CPU, nor single core CPU usage is above 10% when I'm only getting the 46fps, so it must be poor optimization.
I would recommend to check with Intel's PresentMon. That sounds like a severe resource limitation somewhere.
Such low GPU usage would normally imply a severe CPU limit, but if CPU usage is equally low, it might be e.g. a limitation with RAM. Is it running at its rated speed and latency, are you sure it's running in dual channel? Of course it's always possible that it's some form of engine limitation, but I wouldn't be too quick to jump to conclusions without ruling out anything else.
this is a mobile, ahem, "gatcha" game with like a gtx 650 minimal requirements... op must have some weird settings or mods.... impossible to say what they did, with the little to no information we got.
I'd try it "for science", but no controller support means its probably unplayable lol...
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
