New sound card
Mac
I'm thinking about upgrading my sound card from a 50p USB one I bought last year.
I was wondering whether to get USB or PCI.
I don't have much to spend so about £20, I've been looking at the Asus Xonar DG.
Any other suggestions of what I should get?
go usb until you get at least a 990fx board. that way you can still throw a 280x into your rig without dropping your lanes to 8x/4x.
Asus Xonar DG are good, im running creative fatal1ty xfi titanium
and it's great with Logitech 5.1 surround and beats by dre pto
CPU:Intel i7 2700k OC @4.9Ghz cooled by custom water loop with xpsc dual240 rads, xpsc block and 750 pump/res|Ram:G-Skill RipJaw X 32GB 1866Mhz|Case: Corsair 750D|Motherboard:Asus Sabertooth Z77| Hard drive: 240GB Kingston SSD, Seagate 2TB, 1TB Hitachi |GPU: EVGA GTX 770 SC cooled by custom water loop with xpsc gtx 770 block|PSU: Corsair HX750|Monitor: LG 27 inch IPS LED Cinema| Sound Card: Creative Fatal1ty X-FI professional| Build log:
https://linustechtips.com/main/topic/64792-just-finished-off-first-watercooled-rig/
what speakers\headphones are you using?
I'm using a Home Cinema System, but the model number is HT306SF
This.
Get a DAC or something ;)
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
I'm going to need something that outputs from USB if it's external, the sound on this mobo never worked.
hmm. according to the connection diagram on amazon it seems like you can connect the DAC to a computer via USB and then output to either headphones, an amp or active speakers.
No, it only gets power over USB. Edit: That diagram on Amazon is for the E9, not the E3.
Grab this (but don't use the ehadphone port for headphones) instead: http://www.amazon.co.uk/Behringer-UCA202-U-Control-low-latency-Interface/dp/B000KW2YEI/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1382089398&sr=1-1-catcorr&keywords=behringer+uca202
I think the d3 needs an optical or coax input, the usb is just for power.
that receiver is a bit weird, there's no digital input only stereo analog input.
this would probably be the best you can do for around 20 pounds.
http://www.amazon.co.uk/Behringer-UCA202-U-Control-low-latency-Interface/dp/B000KW2YEI/ref=sr_1_21?ie=UTF8&qid=1382089611&sr=8-21&keywords=usb+sound+card
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
Decided I'm going for this
