We've got just about everything we need for my wife's VM/gaming box except the motherboard and RAM. In short, i7-6700, eventually 16GB of RAM. I know gaming systems can work just fine on DDR4-2133 RAM, which opens up H170 boards, but do VMs need faster RAM? She's planning on only running a couple of VMs at a time, so let's say she'll be running 4 at once, worst-case scenario, to be sure.
The RAM question, of course, leads into motherboards. If she needs faster RAM, she needs a Z170 board. If she's good at 2133, a cheaper H170 will suffice. Is she ok at 2133, or will she need more speed?
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/662322-ram-speed-for-vm-box/
My main PC seems fine for multiple VMs at 1600Mhz DDR3 through virtualbox, so I'm sure 2133 DDR4 will be fine.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/662322-ram-speed-for-vm-box/#findComment-8559744
With many VMs the RAM speed is not as important as the amount you have so 2133MHz should be perfectly fine.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/662322-ram-speed-for-vm-box/#findComment-8559891
Thanks @Altecice, @NinjaJc01 and @Analog!
One last question for you guys: given that there's no need for faster RAM and I've confirmed with her (i.e., told her) that she won't be BCLK overclocking, do you think a B150 board would be suitable for VM boxing/light to moderate gaming? Specifically, this B150 board? Her GPU will be a 4GB 960...amazing, I know...and I doubt she'll take it higher than an RX 480, maybe a GTX 1060 at most.
Unless, I mean, I get a 1080 and give her my 1070. But, you know, mortgage.
https://linustechtips.com/topic/662322-ram-speed-for-vm-box/#findComment-8560835
I quite like some of the features on B series boards, especially above H series, but that's Haswell that I have learnt about.
It looks like a good board. Is that crossfire support? I see 2 16xs but I know it doesn't support SLI.
Main Gaming Rig:
Secondary PC:
https://linustechtips.com/topic/662322-ram-speed-for-vm-box/#findComment-8560924
Yep, Crossfire, no SLI. Like I said, she may end up with a 480 or (and I'm really interested in this possibility) two 8GB 470s.
https://linustechtips.com/topic/662322-ram-speed-for-vm-box/#findComment-8561017
8GB 470s? Is that a thing? If not, will it be?
Main Gaming Rig:
Secondary PC:
https://linustechtips.com/topic/662322-ram-speed-for-vm-box/#findComment-8561022
http://sapphirenitro.sapphiretech.com/en/470-8.html
There are others. I think MSI makes one. Boggles my mind, too. A bit of overclocking and you've got a GPU that beats a stock-speed 480.
https://linustechtips.com/topic/662322-ram-speed-for-vm-box/#findComment-8561029
I want one. I think that'll replace my 750 Ti in my second PC nicely, since it's cheap for the performance.
Main Gaming Rig:
Secondary PC:
https://linustechtips.com/topic/662322-ram-speed-for-vm-box/#findComment-8561050
