Please teach me how to pick a suitable amplifier to drive my bookshelf speakers
Solved by SSL,
1 hour ago, Lutkeveld said:I'm of course open to corrections
Sounds right to me.
21 minutes ago, ztmj96 said:So how do you tell if an amp is suitable for a speaker?
Does it put out the minimum recommended power into the impedance of the speaker. e.g. Look at the rated output of the amp into 4 ohms. If it isn't high enough or isn't rated for that output, it may not be suitable.
It's usually advisable to meet or even exceed the maximum power handling in order to avoid driving the amp into clipping.
