Micro ATX / ITX Case for a Deep Graphics Card
Solved by ARikozuM,
21 minutes ago, Timoral said:I have ordered at the Define Nano S and had to RMA it for being faulty. It was also catching the PSU. Great case but no support for cards slightly over the 2 slot limit.
My next suggestion would be the Corsair 88R. You can place the rad on the top or in the front.
One ITX case I can think of that may support the 240mm rad would be the Node 804.
