Nickel CPU block, Silver coil alternative?
Solved by W-L,
Just now, Shadowman said:So which coolant is he best at the moment?
Mayhems makes some of the top stuff currently, similarly with EK. If you just want to keep the fluid as long as possible with the lowest possible maintenance getting a transparent fluid like EKWB EVO or Mayhems X1 fluid wouldn't be a bad idea.
Featured Topics
Triggeravus ·
Posted in Graphics Cards0 -
Aden101 ·
Posted in Laptops and Pre-Built Systems1 -
JordanTrace ·
Posted in Audio2 -
systemdonut ·
Posted in New Builds and Planning2 -
awdasdwasdfgeasdf ·
Posted in New Builds and Planning3 -
4
3
12
andej ·
Posted in Networking1
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
