Need advice for PC build for a friend
12 minutes ago, Jason Jamelo said:Hello everyone!
I was helping a friend to build his 1st gaming rig. He assigned me to do the task since he has no idea on PC build. I choose a mid gaming set up, since he has a limited budget and we are on a third world country , the Philippines. PC parts here are too expensive compare to US pricing, so I tried my very best to choose the best parts for his rig. I don't want to disappoint him later on.
So I make a draft PC parts on pc part picker. Will you guys advice me the best part you had in mind? His budget is around 850- 1,000 USD . All he need is just to game, no content creations, rendering , 3D animations whatsoever. So an 8GB RAM is more than enough I think. The only issue is the best CPU , and motherboard , in terms of aesthetic since I've picked a red GPU on his build which it didn't match to the white MOBO I've picked . Just Please advice me anything you had in mind. I will be very much appreciate it.
Thank you in advance ! Cheers!
Please check my chosen parts here -> https://pcpartpicker.com/user/bourne24/saved/#view=XTYPxr
if you have a little extra or can shave off from somewhere i would recommend putting a ssd on there to and use it as boot drive because it would be much faster and used your hdd as storage other tham that fine no large bottlenecking to be worried about, i bet he will love it and appreciate it much (also you can have him look at NZXT's S340 for a case, barely cheaper but a nice case)
