1080p 60Hz monitor for casual gaming
Solved by samcool55,
http://www.skytech.lt/umwx0eeb01-acer-ka220hqbbid-led-monitorius-ips-technologija-215-coliu-full-1920x-p-319214.html
Not very big but it is the only monitor with an IPS panel that fits in your budget.
And if you want good colors and decent images, IPS is the way to go
And afaik it matches most of the other requirements, you might check them yourself to be sure.
edit: hang on there are more of them, derp, never used the website before
edit2: http://www.skytech.lt/i2369vm-monitorius-aoc-i2369vm-led-ips-hdmidp-garsiakalbiai-p-146058.html
I have that one! Love it It has a bunch of ports so maybe something for you? It doesn't have a very flexible foot but it does have vesa mount support.
