Does the router matters for wired connections?
22 hours ago, Josysclei said:First: Where I live the options are limited and expensive in terms of models I can choose
Second: I don't give a crap about wifi
Third: My connection is 100mbps fiber
As of now, I use a cheap TPLINK WR841 10/100 router that actually bottleneck my internet speed. Having wired connections in mind and maybe ping as an issue (online gaming), will any Gigabit router perform the same? Is it worth it to buy a more expensive model?
21 hours ago, Electronics Wizardy said:If you add a switch it won't matter.
No - it can
20 hours ago, Electronics Wizardy said:The switch will send the traffic to the other system with out going to the router.
While that is partly true, it's not entirely accurate. If the other devices you are connecting to are on the same L2 switch then yes, packets destined for those local devices will not pass through the router. If the packers are destined for the WAN or another subnet that is not on the same L2 switch then it will forward them to the router to deal with.
Switch performance usually scales well with the port count - more ports, generally it'll have the switching capacity to deal with all of those ports.
Routers though don't have this luxury and you can end up being bottle necked by the router trying to process multiple requests of service. If this is caused intentionally, it is known as a DOS attack or denial of service attack.
If you have more questions or what to clarify something, shoot.
