Choosing a cooler under 150mm
raymo39
Hey!
As the title says, I'm putting a build together where the maximum cooler height in the case is 150mm. At the moment I'm tossing up between two Noctuas the NH-L12 and the NH-U9B (leaning towards this one), since both seem to easily outperform the hyper d92 from coolermaster. Just wanted to check around and see if anyone else has experience with smaller height coolers, or any other notable suggestions. Thanks!
Cryorig H7 is a decent budget option but noctua is generally the best in the business performance wise for air coolers (they also charge a lot though), I'm also unfamiliar with the hyper d92 to give decent comparisons to anything
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
NZXT Respire t20 baby! It's been rock solid for more than three years cooling my 3570k oc 4.2 ghz! Temps stay well below 150f even on high load!
My native language is C++
39 minutes ago, raymo39 said:
Hey!
The best cooler under 150mm is certainly the NH-C14S.
https://www.techpowerup.com/reviews/Noctua/NH-C14S/
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
What are the specs of the system?
2 hours ago, WereCat said:
What about BeQuiet! Topflow?
i have one in my hadron air, tight fit. It depends on how much clearance you have between the top fan and the side panel
Silverstone FT-05: 8 Broadwell Xeon (6900k soon), Asus X99 A, Asus GTX 1070, 1tb Samsung 850 pro, NH-D15
Resist!
  • 3 weeks later...
I'm using a Noctua NH-U9S, its 125mm tall so plenty of clearance in the Hadron Air.
Running a 6700k at stock speeds for now and I'm seeing temps of about 28-32 idle and about 70 under full load.
I originally had an NH-L9x65 which idled fine (low to mid 30's) but under load hit mid to upper 80's, That seemed a bit too hot, and why I swapped.
Hadron Air: i7 6700k (@stock), Zotac GTX1070, ASUS Z170I, Noctua NH-U6S, 32GB Kingston RAM, Samsung 256MB 850PRO M.2, 3TB WD Green.
rmurad38
i7 6700k | 32GB Kingston HyperX DDR4 | ASUS Z170I Pro Gaming | Zotac GTX1070 FE | Samsung 950 Pro 256MB M.2 SSD | SanDisk X400 1TB SSD | Noctua NH-U9S Cooler | EVGA Hadron Air
Cryorig H7. 145mm tall, 120mm fan and heatsink, quiet, cheap, beats a 212, let alone a D92 dual-fan money pit. By far and away the best value at the sub-150mm level.
Aerocool DS are the best fans you've never tried.
