Ambient temperatures require beefier cooler?
Solved by ShadowCaptain,
7 minutes ago, Mr.Twabfish said:I live in a house with no A/C, that consistently reaches 80+ Degrees F during the summer. If I was to build a PC would I need a better cooler for my CPU/GPU because of these circumstances? I understand that any conventional cooling method cannot go below ambient temps, but would, say, a AIO make a difference compared to a stock heat sink?
Thanks in advance for any comments.
A top end AIO vs top end cooler produce basically the same result - and is more of a personal choice
but if you have the PC in a hot environment a better cooler will always help
anything better than the stock cooler should suffice
