Best Keyboards and Mouses for gaming?
Masteryodi1980
Go to solution Solved by vanished,
For the mouse:
  • comfort
  • build quality (don't want to be buying another one in 6 months, do you?)
  • good sensor (no acceleration, stutter, etc.)
  • enough buttons
  • buttons in a smart place
  • easy to keep clean
  • software
For the keyboard:
  • Has the switches you want
  • Has the buttons (extra for macros, etc) you want
  • Has the lighting and other gaming features you want (software, etc.)
  • Media keys?
  • Build quality here too
  • N-key rollover (or at least something good enough, like 26 key)
  • Mostly just looks :P
I am going for a total rebuild for everything for my pc! I need to know what to look for when purchasing these two. I will be playing some FPS but mainly single player games like FO4, GTAV, and MMO's and looking to start MOBA's
Personally, the k70 and g502 gets my vote.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
For the mouse:
  • comfort
  • enough buttons
  • software
For the keyboard:
  • Media keys?
