Will I benefit from a cat 6 or cat 6a cable?
Solved by vanished,
1 minute ago, DeadlyPilot said:So would going from one PCs NIC to another PCs NIC be able to reach speeds achievable by CAT6? Since I'll be streaming games I'll need the lowest amount of latency possible with the best quality possible
Not unless you've got 10 Gbit NICs. By default, all computers are 1 Gbit, so you won't come close to needing better cables.
