Nhd15 coil whine ?
Tomic
Got my first noctua product yesterday a NH-D15 1. It's HUGE and 2. It's silent however because it's so quiet I can now hear like electrical whine is it my 280 or a hard drive  all help appreciated
TIA Tomic
Red Fury: Cpu intel i5 4960k GPU 1060 6gb, Cooling  noctua dh15 storage 1tb sshd 250gb ssd mobo gigabyte z97p-3 case fractal r4 ram hyper x fury red 8 gb psu 550w xfx ts os win 10 monitor lg 25um56
TIA Tomic
I doubt its your NDH15 since it has no power phases on it. If it is that, then it means you may have a bad fan or 2 on it. Unplug the fans from your motherboard and see if it continues to "whine" if not, then take and plug them in 1 by 1 off the splitter and see if you can isolate it.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
did you not read his post?
he said "because its so quiet" not that "the D15 is making noise"
read^^^
read^^^
I would suggest the OP change his topic of the thread then as it is mis-leading. I did read it, but apparently not good enough.. Tired eyes at work with 7 more hours to go....
"Black Out"
Could be the HDD esp if its aged abit. GPU coil whine usually go away over time.
ROG X570-F Strix AMD R9 5900X | EK Elite 360 | EVGA 3080 FTW3 Ultra | G.Skill Trident Z Neo 64gb | Samsung 980 PRO
ROG Strix XG349C Corsair 4000 | Bose C5 | ROG Swift PG279Q
Logitech G810 Orion Sennheiser HD 518 |  Logitech 502 Hero
Open your case up and listen for where the noise is coming from. Ezpz
Thanks I will see what it is later
Try powering on the system with the graphics card or hdd uninstalled to isolate the noise.
I think it may be my psu thanks for your help
