I saw this post on a website ( http://www.sciencealert.com/stop-your-computer-overheating-by-stacking-copper-coins-on-it ) where a guy cools computer components with copper coins.
I wanna know if this works. Maybe a Workshop Video on this would do great where Luke (the workshop guy) tries out cooling laptops by keeping copper coins on top also with stuff like network cards where there is no fan on heatsink.
Hardcore Hardware Whore | Check out my Blog for for Latest Tech News and more | Cricket Fan | Weapons Nut |
https://linustechtips.com/topic/613370-copper-coin-cooling/
bullshit. while the theory is correct, that the heat from the pc goes onto the coins is true, that's the principle on which air cpu coolers are based on. I doubt that just putting coins on your laptop will make a difference however
Longboarders/ skaters message me!
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-7926125
But isn't it worth a try?
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-7926131
if you have coins laying around, why not, gotta try it for yourself to know for sure.
I think that yes, the coins will heat up but that won't make the laptop any cooler. Its just an after effect of the coins being near a hot object.
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-7926138
As I mentioned we dont use copper coins in my country, just steel (or nickel)
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-7926141
yea, copper would be the ideal metal for this since it has high thermal conductivity
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-7926149
BS.  A few coins simply don't have the thermal capacity for a laptop that can produce like 40w of heat under load.  Not to mention they don't have the surface area to cool fast enough.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-7926185
You would need to stack the coins on the CPU/GPU die and also use some thermal paste.
Placing it on chassis makes no difference for the hardware temperature. Yes, you are transferring heat from chassis on the coins but chassis is warmed by hot air and not by transferring heat on itself from the die. And even if it would the thermal conductivity would be very poor and it would barely make a difference.
So in theory this could possibly work only on laptops with passive cooling partially made with aluminium chassis... the results would be very poor imo.
Linus did this with submerging Macbook into water but you get far better results with water because it was covering entire bottom of the chassis and made great contact with it.
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-7926186
Putting coins on a laptop won't help its cooling, its just fundamentally wrong. Wedging coins in a heatsink though, if done right it can help(but if you have space to fit coins, you should really just use a better heatsink).
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-7926201
If you actively cool the coins it could. But then you could just have a fan blowing cool air into the laptop which would be vastly more effective as the puny little fans in laptops are shite at doing their job.
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-7926221
this will only help if the coins are in direct contact with the heat source, like in the picture of the card with the coins on it, the pic with the stacks of coins on a macbook is probbaly just BS.  they will only transfer the heat from the case, not from the hot components. it is true however that in more modern laptops the aluminium casing is used as some sort of a heatsink, but you would need a aluminium laptop for that, which are fairly uncommon.
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-7926836
it's not "fundamentally wrong", it will transfer the heat to the coins, the problem here is that the coins are becoming a "passive heatsink" if you will, since there aren't any way to take the "heat out of the coins" it just means it's gonna take longer for the macbook to thermal throttle (the coins are gonna soak the heat and as soon as you get "equilibrium" you're back to step 1).
Linus used the same principle using water;
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-7926878
The coins would simply be working as heat spreaders. Also if you wanted to try this, and you are in the United States you need to get pennies before 1982 to get a decent amount of copper. Albeit the science that proves this true there would not be a substantial cooling benefit considering the lack of surface area. On top of all of this, who wants copper coins lying abruptly on your laptop?
Motivation is where, and what you make of it.
“It is relatively unusual that a physical scientist is truly an atheist. Why is this true? Some point to the anthropic constraints, the remarkable fine tuning of the universe. For example, Freeman Dyson, a Princeton faculty member, has said, ‘Nature has been kinder to us that we had any right to expect.'”  Albert Einstein
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-7927518
14 minutes ago, Little Bear said:
*snip*
It's worth mentioning that if you need to do this then obviously the laptop wasn't well designed, at all...
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-7927593
In theory, but stacking coins on the laptop casing is probably the least effective way of removing heat. Placing coins on the top of a laptop is like putting a big heatsink on a cars bonnet to keep the engine cool, basically it won't do jack shit. There is poor thermal conductivity between the casing and coins(and even between each coin) so that is problem 1, and problem 2 is that there is poor thermal conductivity between the casing of the laptop and the components that are creating heat, since laptops are designed to be 'cool to the touch' while managing the internal thermals(of course, older MacBooks were usually hot externally so for these I could probably let this slide). Unless if a laptop uses the casing as a heatsink(like the 2015 MacBook), all you would be doing is removing the residual heat, which if the method is passive barely anything will actually be achieved, but even if it you made the outside cool to the touch(via a active cooled heatsink or whatever), the inside temps could still be warm-hot(just like a HotPocket. Cool on the outside, blistering on the inside.). There is so much wrong with this, conductivity and surface area being my main concerns(and this is completely ignoring practicality), which is why stacking coins on a laptop to cool it down won't be very effective.
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-7927685
  • 6 years later...
I tried it - and while just stacking them simply led to the coins getting hot before the rest of the Laptop (in the end both the couns and the laptop were hot) I had the absolutely ingenious idea to regularly dump the hot copper coins - which did indeed suck in heat from the hot laptop quickly at first, only to then retain that heat - into a bowl of water. Then fish the now cool coins out, put them in a towel to dry roughly for a moment and finally put them on top of the laptop again to suck out more heat.
The heat is used up when the water gets a little warmer because copper loses heat fast in water. By repeating this process each time the coins become about as warm as the rest of the laptop is, then lose that excess heat in water, resulting in the laptop becoming a bit cooler. This is not that useful most of the time since it takes frequent effort, but it can be useful in summer when you don't have air conditioning and don't want to melt your laptop - or yourself.
Just leaving the coins on top of the laptop (on the line that gets hot easily on that line in front of the screen) is not useful because copper to air transfer of heat isn't efficient at all. Unlike copper to water (which is instantly effective!)
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-15491923
Talk about a dead thread.....
Well, since it's been revived I will say, for troubleshooting sometimes I use tiny heatsinks on CPUs just to see if they're getting warm if a PC isn't powering on. Like, a chipset heatsink etc. And that often can barely handle a 65w CPU in the BIOS. So, coins won't be much better since that's even less surface area.
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-15491949
Not efficient at all due to a few reasons.
Biggest is look at a coin, any coin and tell me with the stamping/image how it's making good contact across it's surface to what needs to be cooled.
The coin itself would have to be flat at least to the side going down on what needs to be cooled.
There is also a question of mass involved for absorbing and moving heat along, a single coin will become thermally saturated almost instantly and remain that way as long as it's being heated. It must be able to pass heat along and to atmosphere at least as quickly as the heat is coming to it but thing is, if there is only a small amount of mass present to absorb the energy, it will not pickup alot of the heat to move along making the item to be cooled build heat.
That's why coolers always have a measured amount of metal/mass in the first place.
Takes mass to absorb a given amount of energy and to pass it along.
Heatpipe coolers are a newer way of moving heat and takes advantage of the wicking effect heat has with a liquid but even that counts as mass to move heat along.
You'd need alot of coins for it to become efficient enough to do the job.....
Then you must have ALL these coins flat on both sides so they make good contact with each other as part of the thermal chain or efficiency goes away.
Your cooling will only be as good as the weakest link in this thermal chain for passing heat along, from the core itself to the chip's lid, to the TIM, to the base of the heatsink/block, to the fins/heat pipes and finally released to atmosphere.
Think about all that for a sec and you'll get it.
"If you ever need anything please don't hesitate to ask someone else first"..... Nirvana
"Whadda ya mean I ain't kind? Just not your kind"..... Megadeth
Speaking of things being "All Inclusive", Hell itself is too.
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-15492419
22 minutes ago, Guest 5150 said:
I lapped a Morgan Silver Dollar once.
Page 5, post #97
https://forums.extremeoverclocking.com/showthread.php?t=343346&page=5
Jesus that was a long time ago now. Almost forgot all about that!
Yep - Had to lap it for the coin to work properly but it did work.
You had some nice reults from it too but since it was silver, that figures right?
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-15492456
I figure a copper coin is no different than a copper plate (IHS) and would only be different in shape and perhaps mass quantity depending on thickness and so forth.
Results where decent. A few degree cooler than the IHS plate, but nothing overwhelming. But definitely was traded for the IHS plate, so the CPU was de-lidded obviously. I didn't stack coins or anything.
https://linustechtips.com/topic/613370-copper-coin-cooling/#findComment-15492460
Guest
