My first build
Solved by Herman Mcpootis,
8 minutes ago, coffeandnovacaine said:Do I really need the RX 480? It seems like a bit much for my needs
it'll last much longer than the current gtx 960/380/380x, with the performance of a gtx 980/r9 fury. definitely worth the wait. you can use the iGPU in your i5 until then, it's still enough for games at mid-low settings.
thedood2k ·
Posted in Power Supplies2 -
DARTHDIVIDER0213 ·
Posted in Troubleshooting8 -
1
Xx-albinos-xX ·
Posted in Troubleshooting10 -
2
_Darasuum_ ·
Posted in Power Supplies6 -
1
4
play_circle_filled
Latest From ShortCircuit:
