Sound dampen Define R5
Solved by Naeaes,
3 minutes ago, ahkenatan said:Has anyone ever tried to put sound-dampening foam in the bottom of the Define R5? What I mean is the space on the bottom of the case from the end of the power supply to the front of the case.
Would this even yield any noticeable sound-dampening benefit?
I've tried with an older case. Not sure if it was R4 or R2XL but long story short, it won't help. If you have noise from such a well-dampened case like the R5, you need to re-consider your hardware in it.
