Wifi Card
Divine_
It plugs into that small slot above where the GPU goes.
  • AMD Athlon X4 760K CPU   |   MSI FM2+ ATX A88X-G45 Motherboard   |   8GB 1600MHz RAM   |   MSI GTX 760 GPU (Reference)
  • Thermaltake Versa H22 Case   |   1TB Seagate, 0.5TB Hitachi (7200RPM)   |   ArcticRed+ 700WStock    |   Windows 8.1
I don't see
That one
8 minutes ago, Joegeddon said:
That one
yeah I did that, but there's a USB cord from the card to the motherboard, idk where that wire goes.
The USB cable you're referring to would go on one of the USB headers. One appears to be behind the sound plugs and the other by the SATA ports.
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
