I'm debating on whether to get the EVGA SuperNOVA 650W P2 80+ PLATINUM or the 750W version there is about a $13 difference with the tax but I don't plan on overclocking anything or run an sli setup, oh and I plan on getting a gtx 1070. If I were to get the 650 will it be more than enough while still having extra room to spare? or should I just go with the 750W even tho I think would be too overkill, thank you all
  • i7 6700k 4ghz
  • cpu cooler: Noctua NH-U14S
  • Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3200MHz
  • MSI Pro Solution Intel Z170A LGA 1151 DDR4 USB 3.1 ATX Motherboard (Z170A SLI Plus)
  • Western Digital 1TB Caviar Blue,  will get an ssd later do to not breaking my budget
  • NZXT H440 Mid Tower Case (Matte Black/Black /w Window)
https://linustechtips.com/topic/598606-psu-help/
650 is more than enough even for OCing
https://linustechtips.com/topic/598606-psu-help/#findComment-7771986
650w would probably be more than enough sli already. It's overkill for one gpu.
Moved to Cases and Power Supplies.
https://linustechtips.com/topic/598606-psu-help/#findComment-7772006
