How much power supply do i need?
Hey guys,
I'm planning to build a new gaming pc and i am not sure as to how much wattage do i really need for my setup. I've tried using the online calculator, but different sites give me different answers, so i'm really confused. The components i'm putting in are,
intel i7 6700k processor
msi z170a krait gaming 3x motherboard
kingston technology hyperx savage ddr4 16Gb (2400 CL12) 2x8GB sticks
nvidia gtx 1080 graphics card
nzxt kraken x61 liquid cooler
Please help me in choosing a good psu for my setup.
around 500w should be pretty good
| i7 4790k | H100i | 16GB (8x2) Corsair Vengence | EVGA GTX 780 SC | ASUS Z97 Sabertooth Mark I | Samsung 840 120GB | WD 2TB Green x2 | Rosewill Hive 750W |
Very good topic on this subject:
"The Rusher" - Motherboard: Asus Z97-Pro WiFi AC CPU: Intel i7 4790K @ 4.4 GHz CPU Cooler: Coolermaster Nepton 240m RAM: Gskill TridentX 16gb 2400Mhz GPU: Gigabyte G1 Gaming GTX 1060 6GB OC Edition Storage: Samsung 850 EVO 250gb // WD Blue 1tb PSU: Silverstone Strider Gold 650w Case: Coolermaster CM 690 III Window + NZXT Blue LED's
The 1080 draws about the same wattage as the 980, 180/165 respectively.
So I'd suggest getting the Seasonic S12II 520w.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151094
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
I have almost the same build, only I got the 980. I have a 650 watt PSU and it works fine. I wouldn't recommend more, since you won't be needing that
EVGA GS or G2 550W.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
Wow, that was quick. thanks a lot.
Any suggestions on which power supply to buy? i'm looking for a fully modular unit
550w G2;
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438053
If you plan on things like getting another graphics card, water cooler or just expanding your build (or overclocking), a higher PSU might be required but if not, then I suggest a 500W or higher PSU.
Thank you
I have another topic regarding which monitor to buy. If you guys could check it out and maybe suggest something, it be quite helpful.
Thanks a lot :)
If you google 'computer power supply calculator', there will appear a site that can calculate pretty accurate total wattage consumption for the system.
http://outervision.com/power-supply-calculator
Google is a powerful tool.
CPU: Ryzen 2 2700@ 4.0Ghz    Mobo: Gigabyte X470 Gaming 7 Wifi    Cooler: EVGA CLC 240    GPU: GTX1080 FTW DT @ 2113Mhz   PSU: EVGA 750W P2
Case: Fractal Design Meshify C   Displays: 34" LG34UC79G, 24" Dell
An EVGA GS/G2 would both suit well. Corsair's RMi is also a stellar unit.
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
Except we always frown upon calculators here as they just spit random numbers out that don't actually correlate to how much power your system actually uses.
Thank you :)
And i know exactly what you mean :|
5 minutes ago, bazingaa95 said:
Thank you :)
No problem! Hopefully those three can find their way into your budget! I'd assume so if you can afford a 1080.
Yeah I'm planning towards the 1080 but i think that by the time i get to buying the graphics card, i might just settle for a 1070, seems quite promising and costs way less than a 1080. Depends on how much i can afford once i put in the rest of the parts. I need a new monitor too.
There would be no reason, for instance, to get an EVGA 650 G2 over the 550 G2 even if he watercools and overclocks. I mean, the unit has a 10 year warranty, it should handle it without any problem, the 550 G2 should indeed. Also, the 650 G2 is not as good as the 550 G2 (less good ripple, PWR_OK troubles) and is usually very poor value comparably.
A 500w should be fine. Hell, you might even get away with 450w, tbh. If you are like most games and "overbuy" on your wattage, go 600w or 650w if you must -- but any more than that is just totally wasting your money,
Trying to be lean on your wattage and devote your savings to better after market fans is not a bad thing. 3 (or 4) Corsair AF140s will make quite a difference in your case airflow and keep everything cool.
Thank you for your help :)
