Hey guys.
Im using my old Compaq laptop which POSTs and boots so fast in windows 10 (5.4sec from button press) from a complete shutdown its mindboggling. Using an ssd ofcourse.
Meanwhile my X99e-ITX board takes ages to post even will all the settings dialed in.
So, the real question is, any idea on what are some of the fastest Skylake compatible motherboards outthere?
I tested a z170a from msi and asus. They both werent as fast a H110i-pro (itx) . Seems like the less feature it has, the faster it POSTs.
Is this a trend or its just a coincidence?
All of the above tested using both 850evo and sandisk ultra plus, mixed results.
Any input helps alot.
Thanks guys.
https://linustechtips.com/topic/595776-fastest-motherboard-post/
I think that is a fair observation. My fastest PC after booting (in sig), is also my slowest PC for booting! I simply don't turn it off and problem solved.
My fastest booting PC is probably an old Haswell box, with Asus H81M-plus. Basic board, no fuss, no overclocking, just boots in seconds.
https://linustechtips.com/topic/595776-fastest-motherboard-post/#findComment-7742412
5 minutes ago, rafazafar said:
It's true that X99 systems take longer to post than Z, H or B series chipsets. X99 platforms have more to initialise on boot.
My fastest booting PC is in my sig. By the time my monitor comes out of sleep and starts displaying an image I'm at the lock screen.
Other systems I've built:
https://linustechtips.com/topic/595776-fastest-motherboard-post/#findComment-7742415
Cool. now i feel like just rounding up a bunch of boards to test if this :)
Sometimes for a larger cluster of PCs, they want to keep most turned off. Sleep mode works i guess but yeah.
Thanks
Yeah X99 really takes ages to load haha. But hey, ze cores.. :)
https://linustechtips.com/topic/595776-fastest-motherboard-post/#findComment-7742424
Thanks
Idea for an LTT Workshop video?
"Do motherboards and chipsets affect POST or boot time?"
https://linustechtips.com/topic/595776-fastest-motherboard-post/#findComment-7742430
disable memory check on startup and enable fast boot
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/595776-fastest-motherboard-post/#findComment-7742438
yes they, do some BIOS will not check everything or skip some stuff to make it appear they are faster
https://linustechtips.com/topic/595776-fastest-motherboard-post/#findComment-7742439
done and done. Its just not as fast, well. simply not fast compared to el chepo simple boards.
Im kinda getting used to the X99 post/boot speed. But just that i build pc(mainly skylake) on a weekly basis for sales, so i would like to put in some faster booting components.
thanks for the tips tho. :)
https://linustechtips.com/topic/595776-fastest-motherboard-post/#findComment-7742448
Yea, my laptop posts (1-2 secs) considerably faster than my desktop, where the post time is about the same amount of time as the windows boot itself.
Laptop is a hm87 (haswell) board, and the desktop is a z77 board.
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/595776-fastest-motherboard-post/#findComment-7742453
31 minutes ago, rafazafar said:
Hey guys.
Thanks guys.
Its funny because my laptop with a 5400rpm hardrive boots in 5 seconds to the lock screen (Windows 10 of course) , whereas an SSD driven system gives me an extra second if it feels like it, but mostly not...
Please vote for Donald Trump. I am out of sitcoms to watch.
When lyfe gives you HDDs, make SSDs
https://linustechtips.com/topic/595776-fastest-motherboard-post/#findComment-7742474
Haha, i have seen that happen to, but only with hybrid shutdown turned on. From cold boot SSD wins handsdown :)
https://linustechtips.com/topic/595776-fastest-motherboard-post/#findComment-7742478
13 minutes ago, rafazafar said:
Sounds like a very interesting idea that wont end up with " It...doesnt matter"
well it doesn't matter, really
you boot your PC like what? once a day?
desktops have to run through a lot more checks like detecting discrete graphics adapters, checking the USB devices, SATA devices, running trough system memory checks, power checks and a lot more, especially for the high end X99 chipset it just has so much more to do - all that + the splash screen to give you a chance to get into BIOS menu without frustration
MSI has a fast boot that just throws your to MBR on power on, completely ignore the POST and boot immediately - the downside is you don't get a chance to get into BIOS
https://linustechtips.com/topic/595776-fastest-motherboard-post/#findComment-7742481
Of course...as it should..
But windows 10 and the hibernating features sure did lessen the gap....
https://linustechtips.com/topic/595776-fastest-motherboard-post/#findComment-7742482
for normal people yes.
As a test bench, sometimes multi times a minute.
Yeah im using a H110 MSI board with "ultra boot". doesnt waste my time with the post message. If i wanted to go UEFI/bios, it allows the user to hold the power button for 4 seconds for direct access..
Just wished my x99 had the same feature haha.
https://linustechtips.com/topic/595776-fastest-motherboard-post/#findComment-7742495
X99, X79 etc take longer to post as they're more complicated and often have more 3rd party controllers.
https://linustechtips.com/topic/595776-fastest-motherboard-post/#findComment-7743010
