Be Quiet Dark Rock Pro 3 vs Phanteks PH-TC14PE
UnjoGratis
I am getting a new pc soon and I am trying to decide what cpu cooler to get between the two listed in the title
please make sure you create the topics in their respective subforums. this allows quicker and solid
moved to Air Cooling
7 minutes ago, zMeul said:
The link shows that the PH-TC14PE performs better.
The DRP3 is quieter though.
be quiet dark rock
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
by 1deg
and when I said it appears to be better, I took into account sound levels too
it gets down to the price and mounting compatibility
11 minutes ago, zMeul said:
by 1deg
The DRP3 has a lower lower limit on noise levels but the PH-TC14PE performs much better for the noise. http://www.silentpcreview.com/article1441-page7.html
They're both the same when it comes mounting compatibility but the Phanteks has better mounting hardware.
