fan setup question
SHADY16
so currently i am using the corsair 200r with clear side window and have one intake in front and 2 exhaust back and top. my idea is to replace the front fan with a corsair SP120 performance and the top and back with corsair AF120s red led and add another AF120 on the top to make 1 intake to 3 exhaust and adding a fan controller to have the 3 exhaust at lower rpm then the fan in the front to hopefully balance them out any tips or advice?
i7 12700k/Asus Tuf z690/32GB Corsair Dominator RGB 3200MHZ/EVGA 3080 Ti FTW3 Ultra/Samsung 980 Pro 1TB/Asus 2540x1440p 165hz Gsync/Acer 2560x1440p G Sync 144hz
Don't go for corsair fans as they have not the best performance. Depending on the budget I'd go for Silent Wings 2 fans or NF-F12 fans, and consider that Static Pressure (SP) fans are good for heatsinks and radiators, while Air Flow (AF) are for the case itself. Hope I helped!
is it possible to have two intakes atleast? 1:3 is very hard to balance
i recommend 2x 120mm at the front as intake and one at the rear as exhaust
and i recommend other fans than those corsair high performance fans, they're quite audible
-sigh- feeling like I'm being too negative lately
Corsair fans perform fine. Their Performance Edition fans perform better than SW2's or NF-F12's but are much louder.
It'd be easier to achieve balanced airflow by having two intakes and two exhausts but it's not that difficult to do it by lowering rpm's with 3 exhausts and 1 intake either.
The fans you've picked aren't that good unless you only care for the aesthetic and don't care about noise.
unfortunately this case only really can do one intake the other fan mount is on the bottom but thats where all my psu cables are and im afraid of the fan hitting the cables also it wouldnt provide as much airflow due to all the cabling in the way of it and the only other one is behind the drive bay. was a cheap 50dollar ish case lol
The fans you've picked aren't great btw unless you only care for the aesthetic and don't care about noise.
I meant the noise, not the performance... my bad :<
I personally would sacrifice 5 degrees more (performance fans) for silence (silent fans) but that's me
eh noise doesnt bother me too much lol i just want good performance with cool aesthetics
Use the bottom or other front mount, just make sure cables aren't being caught, airflow hindrance is a non issue, Luke did a video where he stuffed everything but the kitchen sink in a computer and it had...no effect on cooling, but it's far easier to balance air flow with 2 intakes and 2 exhaust than an off balance setup, easier still with same model fans
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
my other question is how much cooler will i run by just swapping out my current fans with the corsair ones?
well id like to stick with corsair fans to match my case for a theme if you will lol
cooler? you probably won't good video here
desktop
HTPC
