Improving CPU tempratures in a small aircooled rack case?
3 minutes ago, MrCravon said:How much lower temperatures can I expect with the above mentioned Noctua fans over a stock Intel cooler? Will I be able to avoid thermal throttling even when running at 4430Mhz in benchmarks with any or all of those fans?
the L9i would perform almost like the stock cooler while the D9L would perform better
its never a good idea to OC in a SFF anyway
3 minutes ago, MrCravon said:The Noctua fans come with so called "low noise adapters". Do I really need those when the fan is PWM controlled? Or it it only to limit the MAX RPM of the fan?
you can use it and pwm control it, it only limits how fast the fan can spin
though you never want to or even need to run noctua fans at their max speed anyway
4 minutes ago, MrCravon said:Is there a significant reduction in fan noise in the Noctua fans over the stock Intel cooler?
performance per decibel, yes
4 minutes ago, MrCravon said:My idle fan speed on the Intel cooler is around 1000RPM. Will the Noctua fans be able hold a lower idle fan speed as a result of the larger heatsinks?
the L9i hard to say, the D9L probably could
