help moving os to ssd
DH
I've recently installed a ssd and cloned my hdd to the ssd so now both just have an os
i've gone into the boot menu and set the boot to ssd (or atleast i think i have) there is evidence that it has as windows 10 boots up much quicker and everything generally loads faster but when i go into computer management it says the hdd still has the boot and obviously beecause it's the os I cant just delete the os on the hdd so it boots on the ssd :/  can any of you help me? all help is appreciated
you should do a clean install
never clone to an SSD
so what wipe my pc?
I am not sure what you problem is.  Do you not want your HDD to be able to boot?
The MBR has not been deleted off your old HDD.  So it is possible to boot off an HDD still.  However a computer can only boot off 1 device at a time, so if the computer booted from the SSD, then the HDD will just be a regular drive.
Make a backup of your data you need on the HDD. Reformat the SSD. Plug in the SSD and disconnect any other drives. Install Windows to the SSD. Restore data from the HDD.
3 minutes ago, DH said:
so what wipe my pc?
http://www.howtogeek.com/224342/how-to-clean-install-windows-10/
you can just install on the SSD with your HDD unplugged, then plug in your HDD after and move your personal files to the SSD
then format the HDD and use it for mass storage
I dont get what you mean because ive already cloned the os onto the ssd and tried putting the ssd to boot and then i unplugged the hdd to see if that would work but it just came up with a message saying plug in the boot drive
Because cloning is a bad way to do things and sometimes doesnt work properly
even if it did work and you could boot into your SSD you will likely have a lot of windows errors and problems with programs or updates
basically cloning is the lazy way to do things, and as you can see sometimes doesnt work
doing a proper clean install will avoid these issues, and if you havent done a clean install in the past few years then thats even more of a reason to do so
i Just did a clean install like 4 hours ago hoping it would give me an option to boot onto the ssd but it didnt it automatically booted on the hdd
when you do a clean install you need to have the HDD unplugged and the SSD set to boot priority 1 in the UEFI
do not install windows with more than 1 drive plugged in
oh right oaky thanks
I can't unplug the hdd when it's on can i
nope
1 hour ago, Enderman said:
nope
On windows 10 I need to go into the settings to wipe my pc so obviously my pc has to be on, but when I  turn it off and unplug my hdd I cant go back onto windows to wipe it
no it does not
all you have to do is have the SSD plugged in, you put in your windows 10 SSD, then you start installing windows
then you will get to this screen
all you need to do is click format and the drive is clean
no it does not
I don't have a windows disc to get this screen all I get is a black screen like this
did you make a windows 10 USB properly?
are you sure you made it bootable?
7 minutes ago, Enderman said:
no it does not
basically I get insert system disk and press enter on a black screen
I haven't made a win 10 usb?
How are you planning to install windows if you havent made a windows 10 USB???
I didn't know I had to and I only have one 16 gb usb
all you need is a 4GB usb
then just follow the guides:
http://mspoweruser.com/how-to-create-a-bootable-usb-drive-for-windows-10/
5 minutes ago, Enderman said:
I'm looking at the mspoweruser thing and following all the instructions correctly but when it come to the instruction to click on the disk option next to iso image nothing comes up apart from my documents folder when his comes up with a windows download that he can easily click
windows iso file I mean
ok sorry that link was for some other software called ruckus, idk how that works
use this method instead, it uses the actual tool from microsoft
http://www.howtogeek.com/186775/how-to-download-windows-7-8-and-8.1-installation-media-legally/
