Ethernet Switch creating a bottleneck?
Just now, Tyrosen said:I use a Linksys E2500 as a switch. Connect it to my main router, and done. The problem is that the switch has some major bottleneck. The switch bottlenecks the internet from 150Mbps to a low 13Mbps. All devices connected into the switch are slow. What can I do to "unbottleneck" the switch?
Unmanaged switches split their total bandwidth between each of the ports unintelligently, e.g. if you have 8 ports on a 100Mbps switch, the maximum bandwidth they can all provide is 12Mbps (if they are all in use simultaneously), which seems to be similar to what you're experiencing, despite only having 4 ethernet ports - which could be related to this being a router rather than an actual dedicated switch.
To solve this, you could get a cheap 1Gb switch, and that's pretty much it.
