Best fan controller for 40 bucks or less.
hjalli3
Go to solution Solved by KWelz,
NZXR Grid+ V2
So I just put together my pc and turns out that the fans are not very quiet, I bought two of these https://pcpartpicker.com/part/rosewill-case-fan-rfa120rl that I use for intake and then I just used the two led fans that came with the corsair spec 03 case for out-take. It's WAY to loud. I don't want to put the pc on the floor because it's a carpet floor and I don't want dust to build up in my pc, I'm gonna need a fan controller and I was wondering if anyone knows about any good budget ones for no more than 40 bucks. preferably it would be coloured black to match the colour of the case.
I did find this but I'm not sure if it's is good or not https://pcpartpicker.com/part/nzxt-fan-controller-senmix2
From what I've heard the NZXT Sentry Mix 2 is a pretty good fan controller.
CPU: Intel Core i7 3770 @ 3.91 GHz RAM: G.Skill 4x4GB 2133Mhz DDR3 GPU: AMD HD 7970 3GB SSD: Samsung 840 Evo 500GB PSU: Corsair HX620W  Motherboard: Gigabyte Z68X-UD3H-B3 Case: Phanteks P400 Tempered Glass (Black) Monitor: Dell P2412H, Dell 2012H Keyboard: Razer BlackWidow Ultimate Classic Mouse: Logitech G203 Prodigy HDD: WD Black 3TB
NZXR Grid+ V2
Tell my tale to those who ask. Tell it truly; the ill deeds along with the good, and let me be judged accordingly.
