Hi my temps have been running 80-90 degrees on idle. Then when playing arma 3 I run around 100-120. I have asked friends and they have said that is not normal. I thought I need to talk to some "experts"  and possibly find out the cause of these high temps. Please if you have a suggestion to fix this problem please comment.
https://linustechtips.com/topic/574692-h100i-gtx-problems/
F or C
because if its C then your PC should have shut down long before you reached 120C lol
https://linustechtips.com/topic/574692-h100i-gtx-problems/#findComment-7524619
1 minute ago, Enderman said:
F or C
Obviously Fahrenheit lol, but those would be normalish temperatures for a PC at idle and load.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/574692-h100i-gtx-problems/#findComment-7524629
Just now, Aytex said:
120f=48c degrees is too damn low for a AiO
My OC'd 4690k only reaches around 45c at load under an h100i.
https://linustechtips.com/topic/574692-h100i-gtx-problems/#findComment-7524641
4 minutes ago, Aytex said:
oh, ok
Didn't feel like doing a SUPER long stress test or anything but-
Capture.JPG.bc8fe41965926abd8051fa022b07
it didn't budge at all so yeah. Also ambient room temp is 18c.
https://linustechtips.com/topic/574692-h100i-gtx-problems/#findComment-7524674
