Noctua Fans
HD_M4N1CZ
Does anyone know what the best static pressure Noctua fans for the Noctua NH-D14 are?
The fans already on the heatsink. Noctua's stock fans are about as good as it gets.
Other systems I've built:
Are the fans that come with it the best ones for static pressure then? It's just that I thought they'd put some cheap crappy ones on there
Noctua makes some of the best fans on the market, period. They aren't the "cheap out" kind of company.
there are no cheap noctua fans im afraid...
i know there're crap noctua fans
but only their colour resembles crap, their performance is superb
-sigh- feeling like I'm being too negative lately
ehm.... they just look cheap because their puke brown...
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
What they said- the ones they include are really good.
I used to be quite active here.
Noctua places very good fans on their coolers I would just stay with the ones it comes with.
I'm always here to help
NF-A14 industrialPPC-3000 PWM
Static Pressure: 10,52 mm H₂O
*Drools*
*Drools*
it also sounds like an industrial fan though,
i'd rather not have a wind tunnel next to me lol
You need Static Pressure for heatsinks
true
but im pretty sure noctua knows what they're doing when they strap those fans onto the d14 so i think you're getting the best possible results already lol
if you're experiencing high temps, try replacing the thermal paste and mount the cooler tighter (but not too tight)
and improve your case air flow is its not that great yet
true
I don't have this cooler yet xD I'm preparing for an upgrade, but would rather have everything all planned out before I begin to start buying things like I did last time with my AIO
lol, just make sure your case fits the d14 :D
Will do, Getting the Corsair Carbide Air 540 Black :D
These are one of the best fans on the market, noctua delivers only quality products. I can guarantee you you won't find better for that cooler.
I need S340. But more Define S'ish
