Overclocking with no Adaptive Voltage options, alternatives and is it safe
Most overclockers use manual/override and their PCs run just fine. In fact, I have a friend who still has the Sandy Bridge i5-2500K processor overclocked to 5GHz with high voltages and it is still running fine and dandy up to this day. Having that low voltage on a consistent basis is no problem at all (I guess the only problem you will run into is higher electricity bills, but I am sure that is not a concern for you). Other than that, you're pretty okay.
Offset works by adding/subtracting your set vcore. For example, if you have a vcore of 1.190 and your offset is (+) 0.20, it will add another 0.20 voltage when the computer is under load. When you use (-) it will do the opposite and actually reduce your Vcore -0.20 when your PC is idle. If you use the Auto offset voltage (+/- at the same time), it will add +0.20 when your computer is under load and it will subtract 0.20 when your computer is idle.
It is kind of weird that your motherboard doesn't have adaptive settings as I am pretty sure most modern motherboards have that (especially the gaming motherboards). Still, manual/override is still pretty okay.
