Headset cord is broken! PLEASE HELP!
essentially the wires are inside the plastic insulation, then insulated again - coated with enamel, sort of like paint, so they don't short out between each other inside the cable, because audio cables like stereo, have 3 little wires inside the plastic insulation, one for left channel, one for right and one for ground. it sends electric impulses to headset using them and that's how you get sound.
What you need to do is use a soldering iron with some flux (it is used to remove oxidation and clean the cables, strips the coating on the tiny little wires inside too) then solder them using your solder of choice. i've provided pictures, so you can see what the headphones look on the inside, those are just stereo + mic, i assumed yours are too. anyways thats what i suggested you do, the cable being cut, you'll need to clean and put some solder on each of the little colored wires inside and solder them to corresponding ones on the other end, then insulate each from one another with some tape presumably and you'll need to secure it all with something like hot glue, because otherwise they'll just get torn apart very easily (each of the tiny strands has a fiber inside it to give it strength because copper wire in itself isn't resistant to being torn apart)
plan B would be depending on where the tear is also a lot cleaner, to open the headset like you see in my photos and solder the tiny little wires directly to where they used to be, that would make your headphones cable shorter, however make it look clean and be stronger, because it wouldn't have a massive weak point in the middle of it, where the joint would be if you chose to splice the wires together.`
PM me your skype if you want and ill explain what you're missing, or discord or something.
