Really need this on deciding for my 3rd display.
The stupid AMD website says 6 displays, not a max resolution, like Nvidia's.
||| Drakon (Desktop Build) |||
|| CPU: 3800X || Cooler: Kraken X63 || Motherboard: B450 Aorus M || Memory: HyperX DDR4-3200MHz 16G ||
|| Storage: 512GB 970 Pro + 500GB 850 EVO + 250GB 850 EVO + 1TB HDD + 2TB HDD || Graphics Card: RX 5700 XT Red Devil || Case: Thermaltake Core V21 || PSU: XFX XTR 750W 80+Gold ||
https://linustechtips.com/topic/566598-r9-390-max-resolution/
4k?
i doubt you'll buy a display with higher res than that.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/566598-r9-390-max-resolution/#findComment-7443835
Just now, FloRolf said:
4k?
as in 6700000000000000 x 10214324323523524346 or something like that. It Looks like this on the Nvidia website for the GTX 970:
nv.png.f324eef86f76edcbe07aeb390f75daba.
https://linustechtips.com/topic/566598-r9-390-max-resolution/#findComment-7443854
it's not like all 3 monitors together can't be larger than that. You can easily hook up 3x 4k Displays to your 390 or Nvidia card. That'd be 24 million pixels.
Just buy the display.
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/566598-r9-390-max-resolution/#findComment-7443862
So this is PER display? Thanks then :)
https://linustechtips.com/topic/566598-r9-390-max-resolution/#findComment-7443866
1 minute ago, l_zheng101 said:
Most AAA games will run fine at 1440p but some non-demanding games like CSGO and TF2 will run just fine at 4k.
Here for your next time posting:
1. READ OP
2. understand OP
3. Post
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/566598-r9-390-max-resolution/#findComment-7443867
A quick check found the maximum resolution to be 4096x2160.
        Pixelbook Go i5 Pixel 4 XL
https://linustechtips.com/topic/566598-r9-390-max-resolution/#findComment-7443872
yes.
What displays/resolutions are you using anyways? And for what?
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/566598-r9-390-max-resolution/#findComment-7443883
This is still helpful although not the problem, thanks! I couldn't find it anywhere :/
2 minutes ago, kurahk7 said:
Well, technically there is no resolution limit, but a bandwidth limit (for the cable/connector). Nvidia's limit is probably assuming you're running at 60hz.
I see :)
1. READ OP
2. understand OP
3. Post
He could have misunderstood it, it's ok :D
https://linustechtips.com/topic/566598-r9-390-max-resolution/#findComment-7443888
The max resolution is just whatever the display interface supports. The 390 has DisplayPort 1.2, which can support 4096x2304 at 60Hz or 5120x2880 at 30Hz. If you use HDMI then the max is 4096x2160 at 24Hz.
https://linustechtips.com/topic/566598-r9-390-max-resolution/#findComment-7443920
7 minutes ago, FloRolf said:
yes.
Currently 2x 1920x1080 displays as independent displays, where the second one can be used for information during gaming, watching videos, "multitasking" or playing the timeline on a separate screen in premiere pro.
I have a Dell Ultrasharp U2414H 24" 1920x1080@60 and a Philips 226VL 21.5" 1920x1080@60.
I am deciding between:
- A perfect, regular, 60Hz display on the left, same model as my primary screen (total resolution 5760x1080@60)
- 144Hz display in the middle (total resolution 5760x1080@60/144/60)
- Ultrawide display in the middle (total resolution 6400x1080@60)
https://linustechtips.com/topic/566598-r9-390-max-resolution/#findComment-7443923
I reckon its 4k max res. supported
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/566598-r9-390-max-resolution/#findComment-7443968
