Evga 980ti (Output 1x8Pin || Input 2x8 Pin)
Solved by Speakerator,
its fine and intended that way. If you want, you can double check what kind of power the psu delivers on for VGA, but for something so "mainstream" like a single 980TI you'll be good to go
Featured Topics
ShadowSweaty ·
Posted in Troubleshooting2 -
s1eroo ·
Posted in Graphics Cards3 -
CosmicEmotion ·
Posted in Windows5 -
ki8aras ·
Timiii ·
22
jordanbuilds1 ·
Posted in General Discussion6 -
9
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
