I am looking for the best thermal paste for cooling I don't care if I have to replace it often. I know Linus like IC Diamond but does anyone have a better thermal paste suggestion?
I have an Anet A8 as my project printer and a i3 MK3 for when I want things to work.
I extrude my own filament and haven't saved a penny yet.
My PC:
CPU: Intel i7 8700k
Motherboard: MSI Z370-A Pro
RAM: G.Skill Ripjaws V (2x8GB) DDR4-3200
GPU: GTX 1070 Founders Edition (OC'd)
Storage: 2x 2TB Seagate 5400RPM, 128GB ADATA SSD
Power Supply: EVGA Supernova 750w  B2
Cooling: Noctua NH-D15. 3 Intake Fans, 2 Outtake
Case: Fractal Design Define R6
https://linustechtips.com/topic/562514-best-thermal-paste/
IC, Thermal Grizzly, Artic Silver
Those are the best you can get and you have to replace it pretty much only when you swap heatsink or CPU.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/562514-best-thermal-paste/#findComment-7396943
well i did a bit of research on this when i was choosing my thermal paste, there are alot of websites with statistics, mx-4 was the best one in few of them, i went with it and i have had no problems. certainly, anything but the cheapest must be good
https://linustechtips.com/topic/562514-best-thermal-paste/#findComment-7396950
IC Diamond can be corrosive to the cpu if you replace your cooler alot, try MX-4 thermal paster by artic cooling its cheap and one the most used
Case:- 4U Rack Mount Case | Cooler:- Antec Kuhler H600 | CPU:- Intel i5 4690K @ 4.50GHz GPU:- Zotac GeForce GTX 970 4GB AMP! Omega Core Edition @ 1449MHz | Motherboard:- MSI Z97S SLI Krait | PSU:- XFX XTR 650W Gold | RAM:- HyperX DDR3 1866MHz 4GB White (x2) Black (x2) | Storage:- Kingston V300 120GB | Storage 2:- Seagate FireCuda 1TB | Build Log |
https://linustechtips.com/topic/562514-best-thermal-paste/#findComment-7396957
The good ones all perform pretty much the same, the only real difference will be the consistency.
Arctic Silver 5, Arctic Cooling Mx-4/5, Prolimatech PK-3 are for example some of the good ones.
Only when you use the liquid metal pastes, things start to look a bit different, though only about 2-3°C difference.
CPU: i7-4770k (LM modded) - MB: GA-Z87X-UD3H - RAM: HyperX, 16GB 1866MHz - GPU: Palit GTX 980Ti Super - Storage: 1TB HDD + 500GB/120GB SSD (850 Evo/840) - Monitor: Predator XB271HU - PSU: 700W BeQuiet 80+ Gold
https://linustechtips.com/topic/562514-best-thermal-paste/#findComment-7396962
the diffrence between thermal paste with cpu temps is like 1 or 2
https://linustechtips.com/topic/562514-best-thermal-paste/#findComment-7396968
My PC:
CPU: Intel i7 8700k
https://linustechtips.com/topic/562514-best-thermal-paste/#findComment-7396973
Not corrosive, just abrasive.  Major difference.
For pure heat transfer the liquid metals are best.  But they have serious downsides - conductive and almost impossible to remove being two of them.
https://linustechtips.com/topic/562514-best-thermal-paste/#findComment-7396996
I liked IC Diamond. Right up until it scratched the living hell out of my CPU die and probably killed my warranty.
MX-4 and AS5 are my go-tos.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/562514-best-thermal-paste/#findComment-7397023
http://pcpartpicker.com/part/arctic-silver-thermal-paste-as535g
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/562514-best-thermal-paste/#findComment-7397030
