970 sli or 980 ti for better fps?
20 minutes ago, Shinjitago said:I am in a bit of a toss and turn to what to do with my graphics card setup.
Running as follows
Asus Z97-Pro(wifi ac)
Intel i7 4790k(stock speeds, 16 pci pipe)
16gb g-skill ripjaw z 2133 ddr3
Looking at some of linus' test runs between sli and single GPU, it would be beneficial for a secondary(sli) gpu. Rifht now I have a msi gtx970 OC.
I am looking at trying to get Fallout 4 into 4k at around 60 fps(maxed out via moniter/displayport 1.2)
Right now its pretty choppy and rears a bit, gsync monitor is not an option as acer is the only gsync 4k monitor within about a 27 in size.
If i go sli, it will give me only 2-8x pcie 3.0 pipes.
Secondly to all this, another option is to upgrade the board with a cpu that provides a lot more pci pipelines (2011v3) with a higher efficiency for a sli system with 2 gpus running at 16x instead of 8x.
Fallout 4 is the most demanding at this time for the games that I play. Mind you the 970 hits 75C while running 4k in FO4. It is playable but a little annoying to deal with.
The GTX 970 SLI is technically better performance, but the 980ti is the better option for a few reasons:
1. Heat
2. power
3. upgrade-ability
4. not all software supports SLI
5. SLI can be quite buggy/unstable
6. single GPU is always better.
Also, if you ever upgrade, you only need to sell one GPU.
So 1x GTX 980ti, I recommend the EVGA myself.
