Disable auto ISO.
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
https://linustechtips.com/topic/560150-much-noise-plz-help/#findComment-7372136
set the ISO as low as possible and use a tripod+shutter timer
if you dont use a few second delat timer then having your hand pressing the button will blur the image
https://linustechtips.com/topic/560150-much-noise-plz-help/#findComment-7372203
23 minutes ago, FiskenWilliam said:
Where can I turn the ISO down? I cant find it
well, somewhere in the settings...
https://linustechtips.com/topic/560150-much-noise-plz-help/#findComment-7372504
