For gaming?
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7348046
The physical size of the TV doesn't matter. Neither does the fact that it's a TV. What you're best asking is which graphics cards can support 4 monitors at 2560x1440.
And that's just displaying them.
As above, do you want to play games on all of them at once?
Also what TVs do you have that are 2560x1440? That's not a regular size.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7348055
Any modern GPU capable of 4 outputs can run 4x 1440p TVs, but for gaming you'll need quite a lot of horses, think SLI 980Ti / xf R9 390x.
The physical size makes no difference to the GPU, whether your 1440p screen is 1inch or 1000inches, it's still gotta send signals to the same amount of pixels.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7348056
The only difference that TVs make is that it you have a lot of post processing (and therefore 'lag') on TVs compared to monitors.
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7348135
,Can you give us more details ?
Why need to understand what is your intention of going this way, as for surround gaming you need 3 monitors and not 4. and if you intend to game on 3 monitors with surround than we would need to know the resolution, as 3 UHD (3840X2160) each display is a total of 11,520 X 2,160 which no SLI setup would run at any half decent framerate.
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7348508
1 hour ago, TwoTeethGames said:
Sorry, dont know the res but whatever
So is it dual or triple 980ti?
If you don't know the resolution or what you're using it for we can't give you a good idea of the best cards.
if it's 4x1280x720 then you'll even be fine with less than a 780 for gaming. if it's 1920x1080 you're looking at stuff that can push 4k.
That's for gaming on all screens at once. Anything else and you're fine with any GPU with 4 ports that can handle the max resolution on each.
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7348515
You do know the res.  It's 1440p - as stated in YOUR original post.
Laziness is the source of most shit questions on this forum.  Why bother having to log in and type a decently formatted question?
Here's an exercise on how to use google:
Step 1.a:
1) navigate to www.google.com
2) type in 1440p
3) answer is shouting at you from screen
Step 1.b:
1) repeat step 1) from 1.a.
2) type multi display 1440p gaming
3) repeat step 3) from 1.a
I genuinely think this post should be a sticky on LTT...
7 hours ago, ShadyHost said:
Just curious...what TVs run at 1440p?
Also you'd be looking at dual or triple 980ti cards for triple 1440p let alone 4 displays
At this stage though would you not be venturing into the realm of Titan X?  Based on the relatively low RAM on the ti (6GB isn't it?) and that ram cannot be used independently of each card?
Off the top of my head if you were to be gaming on 4 x 1440p monitors you'd need 3 titan x's at least.
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7348912
the fact that you're able to run 4 70 inch tvs tells me that you're also running an industry, richie rich
/jelousy
In all seriousness, the Titan Z can't run triple 4K monitors in favorable conditions so you'll probably need *super* high-end GPUs SLIed.
Well, I guess maybe not the absolute best-of-the-best as it IS 1440p.
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7348952
/jelousy
The 980ti core is a bit faster than the Titan X. I also think the memory speed is a little faster as well. I guess it would really depend what game or application this guy plans to run. If it's something that can utilize as much as 12gb then yeah, the Titan X would be better.
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7349307
Basically any card that can run quad 1440p displays.
Speaking about performance, just read benchmarks. I'd personally go with 980tis or TitanXs in sli, OR fury X's in xfire. It depends on the game you want to play.
you have been visited by ascii stephen harper the pc builder
nothing bad will happen to you unless if you post "ignfdofsginedsoignoifdn" in this thread
why? because you'll be banned for spam
lol
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7349320
and also the size of your wallet xD
I think anyone going for a setup this insane is probably on a very loose budget
It does worry me that this guy doesn't know what 1440p is....and why on earth he wants 4 displays instead of 3....and why they have to be 70inch.
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7349377
*Titan Z!
It's new :3
It's friggin pricey too
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7349551
That's definetly not true as I have triple 4k screens and yes I have 3 titan x's and can still push 60 fps on most games a 4th would allow me to run games even better but then I end of with microstutter as I think there are few videos of people doing it.
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7349592
And at what settings is that ? 60FPS everything ? do you run everything ultra with minimum FPS of 60 ?
Looking at 2 of these titans doing these :
http://www.tweaktown.com/tweakipedia/78/nvidia-geforce-gtx-titan-sli-4k-surround-6480x3840/index.html
so you need the 3rd just to break 60FPS on medium and lower settings? and that Minimum FPS, Just WOW.
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7349623
That's a good graph from tweaktown except a few small hiccups your not accounting for in there graphs.  They are running on presets in each game and running those presets adds different amounts of AA which take gpu power away which at 4K is not necessary like at 1080p etc.   Also just because I run some games on medium settings does not mean it does not look better then lower resolution screens on ultra.  Which if you had a 4k screen you would have realized.  If we compare to my buddies 1440p on ultra you can not notice a difference almost in the two that one is on ultra and one is on medium.   Now the games that are mentioned there are new AAA titles and some older stuff runs well on triple 4k screens maxed out.   I am not sitting here running Shadow of Mordor or anything on triple screens with HD content installed but its nice to have for certain games and I use it rarely now as it just makes me sick after awhile.   So while your comments are nice there are a few in the pc world who do run triple 4k screens and enjoy it.
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7349935
Its to run a slideshow of pics
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7351893
That's why I have asked you, you don't need any of the super expensive gpu's that were talked about, just something that can output the needed.
Do you intend to tile them To get 2X2 ? Also the resolution(as you are not sure its 1440) and supported display inputs of the monitors would help in recommending a GPU.
https://linustechtips.com/topic/558315-running-4-70inch-tvs/#findComment-7353560
