Help me with picking out a loop
13 hours ago, Octavialicious said:Awesome. I sincerely thank you for your help thus far, I would be lost without it
Going to buy it tomorrow morning, does it look good to order? I have a kill coil coming in from amazon to deal with growth in the loop, and PWM splitters as well. And obviously I will get a GPU with a block soon
That all looks about good I would go for the Mayhems coolant if you can they make some good stuff, not too sure about the pastel series from XSPC yet since they are somewhat new still.
One very important thing is to not use a silver kill coil in this loop, the premixed stuff will take care of everything, the reason being that the lian li block you have is nickel plated, nickel and silver are borderline dis-similar metals in a loop environment which can potentially cause issues with the nickel plating.
