Very hot m.2 drive! help?!
Go to solution Solved by gazabi,
1 minute ago, RyanFawcett said:
So my Samsung 850 evo 500gb m.2 ssd is running at 68°c-73°c, Samsung's website states that these drives can operate between 0°c-70°c.
Im a little worried... any ideas anyone?
Thankyou!
I believe its normal, reviews show that this drive can get even hotter.
This review shows it:
https://www.pugetsystems.com/labs/articles/Product-Review-Samsung-950-Pro-512GB-M-2-Drive-725/
Thankyou!
i5-6600k | MSI GTX 970 | Asus Z170I | Samsung 500GB 850 EVO M.2 | Kingston Hyper X 2133Mhz DDR4 8GB | Silverstone SG13 | Silverstone SST-ST55F-G
https://linustechtips.com/topic/550669-very-hot-m2-drive-help/
Thankyou!
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/550669-very-hot-m2-drive-help/#findComment-7269282
Wow! upwards of 115°c on a drive... makes me feel slightly better haha
My drive is on the back of my motherboard, inside a Silverstone SG13, so literally zero airflow back there. What would you guys suggest? just some thermal pads?
https://linustechtips.com/topic/550669-very-hot-m2-drive-help/#findComment-7269318
Thankyou!
Can confirm what others have already done so on this thread. mSata and M.2 drives get HOT, even if they're just idling sometimes.
I've got a Crucial MX200 500GB mSata drive in my 2012 Samsung Series 9 laptop, and it gets up to around 60-90*C regularly, even with the cooling pad connecting it to the laptop's all-aluminium body. Just the nature of the game.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/550669-very-hot-m2-drive-help/#findComment-7269604
42 minutes ago, TheCovertCamper said:
Normal. My SanDisk SSD that is 2.5" runs at 80-90 all the time and the 950 Pro's are known to be toasty.
That doesn't seem normal, did you have a very small case and a hot OC'd GPU? My SSD never hit 50C even on a hot day.
"32ºF to 158ºF (0ºC to 70 ºC)"
https://www.sandisk.com.au/home/ssd/ssd-plus
https://linustechtips.com/topic/550669-very-hot-m2-drive-help/#findComment-7270257
No, it's in the SSD bracket on the back of the computer and it's an Ultra II.
https://linustechtips.com/topic/550669-very-hot-m2-drive-help/#findComment-7270293
M.2 drives as a general thing do run hot. SATA run about what you're seeing - 55-75c while PCIe/NVME versions are often between 90-115c - If you open a good quality laptop, chances are there are termal pads on the NVME drives similar to the ones you'll find on VRAM chips on a GPU. PCI based NVME drives use rather large heatsinks to disipate this heat (pictured below)
https://linustechtips.com/topic/550669-very-hot-m2-drive-help/#findComment-7270665
Note the spec usually for the ambient temperature usually not the die temperature it reports. Although I highly doubt it will operate well at 70degC ambient as the throttling would be intense at that starting temp. M.2 drives do get very hot this is just due to the form factor. I'd use a heat spreader over the controller if your worried about it. Heat does technically reduce reliability.
https://linustechtips.com/topic/550669-very-hot-m2-drive-help/#findComment-7270919
  • 2 years later...
I have a Corsair MP300, runs at about 60-63C in a location with good airflow and no heatsink. I thought that was hot but I did some write speed tests and found no (significant) difference between advertised, cool and hot speeds.
i5 8600 - RX 6600 - Fractal Nano S - 1080p 144Hz
https://linustechtips.com/topic/550669-very-hot-m2-drive-help/#findComment-11938814
