Reccomeneded Hard Drive?
18 hours ago, IsaacDaGrazin said:~snip~
Hey there IsaacDaGrazin
I'm sorry to hear about the troubles with the drive. It's always frustrating when you deal with problems like this.
Have you tested your drive to determine what's wrong with it? Maybe try plugging it as a secondary drive in an already working system and run some diagnostic tools and check its S.M.A.R.T. status with the raw values? I'd use the manufacturer's tool and see if the drive passes it at all and if it doesn't - what errors are there. Feel free to post it here if you have trouble reading them.
Regarding the Western Digital drives, the guys basically gave you pretty good and correct info.
WD Blue is your regular everyday drive that is most commonly used for regular computing, light gaming and workloads and combined with SSD. It is fully capable to run most games as well as many programs for editing or programming. http://products.wdc.com/support/kb.ashx?id=zeacBp
WD Green is your energy-efficient drive that works cool, quiet and saves a lot of power. It is designed for backups and secondary storage. Its features allow it to be a great choice for quiet backup builds or for archiving. It is mostly chosen for massive media storage (up to 6TB) in builds that have another drive for the OS and active programs and games. WD Green is getting integrated into the WD Blue line. http://products.wdc.com/support/kb.ashx?id=xae9bm
WD Black is the performance drive in WD's consumer line. It is the fastest among them and has good features such as a built-in dual-core CPU that makes the drive great for multitasking. It is designed for heavy gaming, big workloads and intensive file usage. It has a llong, 5-year limited warranty and its mostly used in gaming computers or editing machines. http://products.wdc.com/support/kb.ashx?id=KhpHQD
WD Red is the NAS/RAID class drive from the consumer series that is designed specifically for RAID environments and NAS devices. It is tuned and optimized for 24/7 performance, RAID arrays and up to 8-bay NAS systems. This drive is often used for backups, stable secondary storage and in streaming builds, as well as NAS and RAID. http://products.wdc.com/support/kb.ashx?id=P1AbZQ
WD Red Pro is designed with the same purpose as the regular WD Red, only for larger scales (8 to 16 bays). They have fixed 7,200 rpm (while the regular WD Red has Intellipower), longer warranty and some additional features in the firmware, enabling it to perform even better at larger scale RAID arrays. http://products.wdc.com/support/kb.ashx?id=g59F3q
WD Purple is your surveillance-class drive, designed specifically for surveillance storage, video recording and streaming. It has optimized noise reduction (being the most quiet drive in the consumer line with only 22dBA nooise level during seeking time), significantly reduced frame loss nad optimized firmware. This drive is also used often for desktop computers due to its low noise levels. It has optimized sequential read/write speeds but the random read/write speeds are lower than normal and some people experience problems with it in regular desktops. http://products.wdc.com/support/kb.ashx?id=HNVQiZ
WD Purple NV is pretty much the Pro equivalent of the regular WD Purple with the difference that it is designed for NVR systems. Here's more details about it: http://products.wdc.com/support/kb.ashx?id=GkT4Hv
WD VelociRaptor is a fast workstation drive, spinning at 10,000 rpm. It has limited capacity of 1TB and is mainly used in workstations for editing and content creation. People start to replace it with SSDs but still a lot of users prefer regular HDDs. http://products.wdc.com/support/kb.ashx?id=fjS6U1
WD Black2 is a dual drive that combines a 120GB SSD with a 1TB HDD in one enclosure in 2.5" form factor. It is designed specifically to improve laptop capacity and performance. It is different from a hybrid SSHD because the SSD part is much bigger (120GB compared to 8GB) and works independently from the HDD (while you cannot control what goes on the SSD part of a SSHD). It is mostly used in laptops with only one drive bay for both speed boost and capacity improvement. It's no longer in production. http://products.wdc.com/support/kb.ashx?id=2wCYE3
WD AV is a drive that is designed specifically for 24/7 streaming and PVR, DVR and IPTV environments. It is an earlier version of the WD Purple and is still used for constant streaming in TVs, media players, etc. http://products.wdc.com/support/kb.ashx?id=2DCo8i
WD Blue SSHD is a hybrid drive that is designed for single-bay systems and can provide a great boost in performance for your most used applications by caching their files on the SSD portion. http://products.wdc.com/support/kb.ashx?id=dcbLpU
In your case I would go for either WD Blue or WD Black, depends on which one fits better your needs and budget.
Feel free to ask if you need more info on any of this or if I can help with anything else
Thanks @Stefan1024 for mentioning!
Captain_WD.
