"Expiration" is a difficult thing to define, as it means different things for different forms of edible and drinkable matter. Water won't decompose into anything unsafe, but leave water stagnant enough for long enough in the open air and it will start feeding colonies of algae and bacteria. In enclosed packaging or at low temperatures though, water pretty much keeps for eternity.
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
https://linustechtips.com/topic/541730-does-water-expire/#findComment-7171728
No, the same water has been on earth for billions of years.  That said, any specific volume (say, in a bottle) could go bad if things start growing in it
https://linustechtips.com/topic/541730-does-water-expire/#findComment-7171770
No it doesn't ??
However, I'd swerve drinking water that came out of a polystyrene cup that was in the microwave or in the sun because you know... Benzene.
If you refill bottles then you should wash them properly before re-using them as bacteria can build up at the mouthpiece which would smell.
https://linustechtips.com/topic/541730-does-water-expire/#findComment-7171889
Who can say for sure but I'm sure it will last longer if you freeze it
You know how it is, the cow goes "moo", the dog goes "woof" and the gamer goes "The PvP is unbalanced."
Personal Computer: CPU: i7-4790 Mobo: Asrock Z97 Extreme6 Graphics Card: MSI R9-380  Memory: 16GB (8GB x2) G. Skill Sniper Gaming Series PSU: Apevia Warlock 750W Case: NZXT Phantom 410 Series Storage: 240GB SSD (OS) 3TB HDD (data and such) 500 GB SSD (Movies and Large Data Transfers (I'm constantly moving this one around to other computers))
https://linustechtips.com/topic/541730-does-water-expire/#findComment-7172371
not really, but if you have it in a plastic bottle the plastic may give to the water giving it a different taste
https://linustechtips.com/topic/541730-does-water-expire/#findComment-7172493
Water if moving will eventually be cleaned by the Earth it passed through and over, like a huge filter.
I rember in the Army drinking water off the top of a mountain in Wales on exercise.. best water i had ever tasted.
CONSOLE KILLER: Pentium III 700mhz . 512MB RAM . 3DFX VOODOO 3 SLi
https://linustechtips.com/topic/541730-does-water-expire/#findComment-7172502
To clarify something that I've noticed, I'll say this:  When we talk about the concept of food "expiring", it is a combination of things.  For one, food is made (generally) of countless, complex molecules.  Organic molecules, that break down and change.  This is part of the process.  There are also micro things living on it, and these multiply exponentially.  In tiny quantities it's fine, but once enough form (ie, the food moulds for example) then you don't want to go near that.
Water will not decompose, but the same idea of things living in it multiplying until it is a problem does still exist.
https://linustechtips.com/topic/541730-does-water-expire/#findComment-7172579
The water it self will not go bad.  But chemicals can leach out of the container it's in and contaminate it.  That's where the expiration date on bottled watter comes from.
01010010 01101111 01100010  01001101 01100001 01100011 01010010 01100001 01100101
https://linustechtips.com/topic/541730-does-water-expire/#findComment-7173158
