Help me decide between 8GB-16GB or 3000mhz-4000mhz
Solved by thatguyyouknow75,
Just now, RGT said:16gb will be but, what is best, 3000, 3200, 3400, 4000 mhz?
The lowest speed. Unless you plan on extremely intensive rendering (in which case you'd have 32-64gb) the speed does not matter with ram. No amount of tabs or AAA games are going to be limited by the available speeds. Go with 3000,its a great price. If you can find it at a lower speed for cheaper then take that
Featured Topics
Master_Kilvin ·
Foure ·
Posted in Networking1 -
PowerPCFan ·
Posted in Windows8 -
clutchmaster ·
Posted in Tech News6 -
2
Steve_6502 ·
Posted in CPUs, Motherboards, and Memory1 -
5
