Need quieter fans...
Solved by iamdarkyoshi,
Actually, right now, my fans are running quiet enough to be basically silent. I MIGHT adjust the fan curves on my controller to make the fans run at their min. speed at 25 degrees, and make it so when the PC starts, it runs the fans fast for a second or two, just to make sure that I avoid that "start voltage"
I will look into the noctua fans or the bequiet fans and make a decision whether I want to buy them or mod the fan controller to be smarter.
