Soft or hard mouse pads?
By
niofalpha
in Peripherals
in Peripherals
Solved by ZetZet,
Cloth mouse pads have more grip, mouse stops on it's own, hard mouse pads have more glide.
Also lift-off distance is different, but that depends on the mouse.
For optical mice you generally want a cloth pad since it has more texture so sensor has stuff to scan, however some hard pads are textured enough and work just fine with optical mice.
kisserik93 ·
Posted in Peripherals4 -
Rick13 ·
Posted in CPUs, Motherboards, and Memory11 -
6
popularlion ·
Posted in Troubleshooting5 -
2
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1
