Buying a 2K monitor or 4K?
0. 3840×2160 is a 4K resolution because it is ~4000 (4K) pixels horizontally, likewise 1920×1080 is a 2K resolution since it is ~2000 pixels horizontally, and 2560×1440 is a 2.5K resolution. Just something to keep in mind. 1440p is not a 2K resolution.
1. 3840×2160 is like a 2×2 grid of 1080p monitors, so you gain quadruple screen real estate in theory, but this is only if you leave scaling at 100%. In practice, you will probably not gain that much screen real estate. If you could imagine a 24" monitor being divided into 4 quadrants, and shrinking your 1080p screen and everything displayed on it into one quadrant of that monitor, you will be able to fit much more stuff but of course all of your applications and text would be extremely tiny. You would need to have applications be scaled up to a readable size, like the same size they'd be on a 24" 1080p monitor. Since a 4K monitor has many more pixels, everything would be sharper, but applications would still take up the same amount of space on the screen if you scaled everything all the way up to 200%. A 1440p 24" monitor at 100% is about as low as most people are comfortable without any scaling, so if you got a 4K monitor you'd probably have to scale everything up to a similar size anyway, so the amount of screen real estate gained on a 4K vs 1440p monitor is pretty much equivalent, unless it's a very large (32"+) 4K monitor which you may not need to use scaling on.
2. Yes, you can lower games to 1920×1080 resolution on a 1440p or 4K monitor and it will still fill up the screen without any black bars etc.
3. Whether everything is tiny or not depends on your scaling settings, which are adjustable to however you like. You can make things tiny if you want, but Windows 10 scaling will allow you to make everything the same size as it would be on a 1080p monitor, or a size inbetween if you want.
4. Scaling is ok. Most programs scale fine but there are some exceptions, such as Origin.
5. No, the field of view in most games (including League) will be the same on any 16:9 display, regardless of resolution. Since 1080p, 1440p, and 4K are all 16:9 ratios, the actual image will be exactly the same, it will just be rendered with finer detail.
Thanks for this. I'll probably go with a Quad HD monitor more than likely one of the ASUS ones I've been looking at.
