Can i use vodka for thermal paste removal?
Main: Gigabyte G1 980Ti, i5 6600k, MSI Z170A M5, 16GB DDR4 2666, NZXT H440, NZXT x61, EVGA 750W G2, Windows 10
Second PC: EVGA Reference GTX 680, i7 2700k, 16GB DDR3, Corsair 300R, Corsair CX500W, Windows 10
Laptop: Acer Aspire 5750G, GT540M, i7 2630QM, 6GB DDR3, Windows 7
https://linustechtips.com/topic/533180-vodka-for-thermal-paste-removal/
You can use whatever you want...
however, there may be consequences for your actions
I'd generally avoid it as the idea of a remover is to remove all the residue and have the substance evaporate away + not eating your board is a plus. So, rubbing alcohol is always the best way to go, but i've used harsher substances like acetone before.
The Vinyl Decal guy.
Celestial-Uprising  A Work In-Progress
umm why?
I don't have 99% alcohol stuff
just use water
just use water
Really? On like every youtube video they say alcohol
water works fine
alcohol just evaporates faster and helps dissolve the paste if its old and dry
if you just rub it well with a wet cloth it will work just as well
You dont really have to use anything as long as the thermal paste is relatively new it wont be really crusty and a microsfiber cloth with a bit of scrubbing will get it off without liquid.
It's about 2 months old, it came with the NZXT x61 AIO. And i bought the arctic mx4 yesterday. Also the cpu has been in a plastic case for a few days because i changed mobo. Idk it looks kinda okay.
You don't need to use alcohol. And the alcohol content of vodka isn't high enough for it to really be ideal. It's more water than alcohol, so it's not a safe idea.
Use a can of deodourant if you have to.
DAYTONA
PROCESSOR - AMD RYZEN 7 3700X
MOTHERBOARD - ASUS PRIME X370-PRO
RAM - 32GB (4x8GB) CORSAIR VENGEANCE LPX DDR4-2400
CPU COOLING - NOCTUA NH-D14
GRAPHICS CARD - EVGA NVIDIA GEFORCE GTX 980Ti SC+ ACX 2.0 w/ BACKPLATE
BOOT and PROGRAMS - CORSAIR MP600 1TB
GAMES and FILES - TOSHIBA 2TB
INTERNAL BACKUP - WESTERN DIGITAL GREEN 4TB
POWER SUPPLY - CORSAIR RM850i
CASE - CORSAIR OBSIDIAN 750D
  • 4 weeks later...
Sorry for necroposting but.. If anyone reads this, what else can be used for thermal paste removal? Nail polish remover, ethanol, methanol, beer, will denaturant evaporate? And does it matter to leave absolutely no substance before applying new paste? Because come on, thin layer of some oils etc couldn't cause the CPU to heat up more, could it?
I need S340. But more Define S'ish
