CAR AUDIO, In line equalizer?
Go to solution Solved by Enderman,
you mean a high pass filter?
So i just installed a cheap radio and some cheap subs in my ceap car (seeing a theme?) and i realized that the mid bass was feeding to both the terrible stock speakers and my sub-woofers. is there such thing as an in line equalizer, that cuts out the mid bass and allows the stock speakers to shine with just mids and highs?
thanks everybody!
https://linustechtips.com/topic/533118-car-audio-in-line-equalizer/
Usually the radio has an EQ and some of them have one that you can customize.
I know mine has a couple of presets and 2 custom presets you can adjust as much as you want.
Soo if you radio doesn't have it, then that's what you get for getting a crappy radio :D
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
Put a 270uF bipolar capacitor (25V+ rated) in serie with the midspeaker wiring.
This will form a so called 1st order RC high pass filter at 150Hz.
Since it's a cheap install you could just go with a simple electrolytic type.
If you want to get fancy you can bypass (put in parallel) it with a small poly capacitor.
Even better would be to find the highpass setting on your radio (if it has one), and apply highpass on the midbass channels
