Yes. but why not fold on your 970?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
I'll use it for when I game and then reconfigure the profile so that I have that GPU folding when I'm at idle. No cancer will be safe from me!
I say jiggly-bytes when I see "GB".
It goes down better than you would expect.
Because he wants to have it live not burning or dying in 1 year
because that what happens when folding....
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
You know that folding is FAR from being that stressful, right? Even OCed, folding doesn't really pump up all that heat.
You know that there diseases other than cancer being researched, don't you?
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
I wanted to do that, but I am too lazy to get and rewire a new PSU ;(
Quiet Whirl | CPU: AMD Ryzen 7 3700X Cooler: Noctua NH-D15 Mobo: MSI B450 TOMAHAWK MAX RAM: HyperX Fury RGB 32GB (2x16GB) DDR4 3200 Mhz Graphics card: MSI GeForce 3080 GAMING Z TRIO PSU: Corsair RMx Series RM750x Case: Be quiet! Pure Base 600
Buffed HPHP ProBook 430 G4 | CPU: Intel Core i3-7100U RAM: 4GB DDR4 2133Mhz GPU: Intel HD 620 SSD: Some 128GB M.2 SATA
Retired:
Melting plastic | Lenovo IdeaPad Z580 | CPU: Intel Core i7-3630QM RAM: 8GB DDR3 GPU: nVidia GeForce GTX 640M HDD: Western Digital 1TB
The Roaring Beast | CPU: Intel Core i5 4690 (BCLK @ 104MHz = 4,05GHz) Cooler: Akasa X3 Motherboard: Gigabyte GA-Z97-D3H RAM: Kingston 16GB DDR3 (2x8GB) Graphics card: Gigabyte GTX 970 4GB (Core: +130MHz, Mem: +230MHz) SSHD: Seagate 1TB SSD: Samsung 850 Evo 500GB HHD: WD Red 4TB PSU: Fractal Design Essence 500W Case: Zalman Z11 Plus
My preference for research is cancer.
Exactly. Few people know, but the server actually just sends whatever it wants to you.
That doesn't really happen with folding... aslong as its not running in the upper 80s lower 90s u should be absolutely fine
CPU: R7 5800x -- Mobo: Gigabyte B550 Gaming X v2 -- RAM: 2x16GB Kingston Fury Renegade -- GPU: Asrock RX 6800 XT Phantom Gaming OC -- Case: Fractal Design North Walnut/Black Mesh -- Storage: 2TB 970 Evo Plus, 4TB NM790 -- PSU: BeQuiet Pure Power 11 Platinum 650w -- Displays: AOC AGON  AG352UCG, Dell Ultrasharp U2715H -- Cooling: Noctua NH-D14 -- Mouse: Corsair M65 -- Keyboard: Func KB 460 MX Blue -- Sound: Motu M2 -> THX 789 -> DT880 600Ω -- Mic: RØDE NT1-A
RIG 2: Intel i5-8400, 16 GB RAM, RTX 2070S
My 560 Ti Has been folding since release.
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
I was thinking about getting a 750Ti for folding while I use my 970 for normal use. Can I do it in the same rig?
Nice to see u using a 750ti did u buy that separately just for folding?
It was one of the first GPUs I'd ever bought, so I thought instead of just letting it sit and collect dust I could re-purpose it to do something good!
Atleast ur contributing to a good cause that said are u running an overclock on it?
I can't really run a stable overclock on it as there is no 6 or 8-pin connectors, but I'm getting about 30K PPD, but with my 970 running as well, I'm getting about 380K PPD overall!
There should be no problem with overclocking those cards without PCI-e power I have 2 750tis and the run at 1390 at the moment just stable folding every weekend 24/3 no problem whatsoever and 30k seems abit low mine are both outputting anywhere from 70k to 85k
Ah, I was looking at the EC for the WU. Silly me :D
I'll take a look into some slight overclocking on it as well. It'll probably be quite mild as I don't want any failed WUs :)
