How should I clean the windows of an H440? (With what liquid and what kind of rag)
Soft microfiber cloth or cotton with ideally just some water, if it's really dirty a little isopropyl and water solution (<50%) is what I tend to use.
Use a micro fiber cloth and any water based cleaner. Do not use any alcohol based cleaners, as it will make the window cloud up and crack. Using canned air also helps too.
CPU: Intel Core i7 4790K @ 4.6 GHz
Motherboard: Asus ROG Maximus VII Hero
RAM: Corsair Vengeance 32 GB @ 1903 MHz
GPU: Nvidia GeForce GTX Titan X @ 1100 / 7030 MHz
Case: Corsair Obsidian 750D with the Ghetto LED 5000 lighting kit
Storage: 1TB Samsung 840 EVO
PSU: Corsair AX1200i
Display: Dell P2415Q
Cooling: Corsair H100i
Keyboard: Corsair Vengeance K95 RGB (Cherry MX Reds)
Mouse: Sharkk MMO Pro
OS: Windows 10 Pro
Intel Core 2 Quad Q9550
Gigabyte GA-G41MT-S2PT
Arctic Freezer 7 Pro Rev 2
G.Skill Value 8 GB (1333 MHz)
Cooler Master N200
Seagate Barracuda 1 TB
Insignia 300W
Windows 7 Enterprise
Intel Core i3 3240
Asus P8Z77-V LX
4790K stock cooler with Cooler Master HTK-002 thermal paste
Corsair XMS3 4 GB (1333 MHz)
Cooler Master HAF 912
Thermaltake TR2 430W
Windows 10 Pro
Water and a cotton shirt
Ok thanks
Breaking things 1 day at a time
Ok thanks
I have heard that rubbing a dryer sheet on it will help prevent static dust collection (something that my PC does far too often, I cannot keep the side window clean for 5 seconds) but it might scratch it or leave a residue...
*tries*
*window gets destroyed*
OS: Windows 10 Pro
Cooler Master N200
Insignia 300W
Intel Core i3 3240
Asus P8Z77-V LX
Windows 10 Pro
interesting. Ill try it. I really wanna replace it with tempered glass too
AAAANNNNDDDD it scratches. A little. It sort of goes away tho
Ya thats what I worried about. Elbow grease and a little bit of toothpaste can buff out scratches. I have fought really bad scratches before and this seems to work the best. And it smells minty.
damp microfiber cloth
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Wa
Water seems to get it out. I do have a huge ('huge' (like 1Cm line)) that got there the day i built it. Will toothpaste get that out? And do you use a toothbrush?
microfibre cloth and a little water
Wa
I used a cotton rag (AKA T-shirt) and just toothpaste and a little bit of water. Get the whitening stuff and TEST IT IN A HIDDEN AREA FIRST. It has abrasives in it designed to polish teeth, some abrasives are more aggressive than others, which is why you want to test it in a hidden area. You can also use it to polish heatsinks, I once got a stock intel cooler looking like this: http://static.commentcamarche.net/www.commentcamarche.net/faq/images/0-KJY0AVni-img-1824-s-.png
ok ill try it
and now it looks worse... Ill have my dad help me later tonight maybe
Hmm... Like I said, some pastes are more agressive than others. I have had decent luck with cheaper plain toothpaste....
Welp time for tempered glass! xD
Honestly, I would invest in a tempered glass replacement. It's so much easier to maintain.
OS: Windows 10 Pro
Cooler Master N200
Insignia 300W
Intel Core i3 3240
Asus P8Z77-V LX
Windows 10 Pro
You should see the PC in my signature, the cablemod sponsored build. Holy shit that thing is a BITCH to maintain.
Best to get proper plastic/acrylic polish like novus they work really well. As for going to a glass panel instead that would be the best of both worlds since it doesn't scratch very easily.
http://www.amazon.com/NOVUS-7100-Plastic-Polish-Kit/dp/B002UCYRZU
Alot of water and a microfiber cloth helps but its not perfect
